Call Manger Processes are (mostly) sleeping
doug syer
im polling call manager processes and im finding that for the most part they are in the "Sleeping State"  at first I thought that I was matching the wrong code up but then i double/triple checked it against docs and against the counter description in the API.
I want to make sure that this isnt a bug and is normal.  its not that i never see other states, i do but most proccesses are sleeping including call manger.
Im assuming that perhaps the threads are active while the master process is sleeping but I wanted to confirm that this isnt a bug in the api/docs.
d
dstaudt
I believe this is quite normal, especially for a system not under load.  Compare to the CUCM CLI command (i.e. top) for 'show process load':
admin:show process load
top - 09:14:08 up 8 days, 13:40,  1 user,  load average: 0.21, 0.16, 0.09
Tasks: 241 total,  1 running, 240 sleeping,  0 stopped,  0 zombie
Cpu(s):  4.8%us,  3.6%sy,  0.0%ni, 91.5%id,  0.0%wa,  0.0%hi,  0.1%si,  0.0%st
Mem:  5994176k total,  5871080k used,  123096k free,  243736k buffers
Swap:  2047992k total,  182228k used,  1865764k free,  1988068k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
21231 Administ  30  10 1261m  95m  13m S 27.4  1.6   0:04.41 java
6353 ccmbase   20   0  371m 128m  30m S  2.0  2.2 156:02.04 ccm
10021 ccmservi  20   0  439m  81m 6096 S  2.0  1.4  17:13.01 UserSyncService
10256 ctftp     20   0  646m  53m 6928 S  2.0  0.9 149:54.05 ctftp
13036 root      20   0 34744 4916 2612 S  2.0  0.1   4:50.74 clm
23879 Administ  30  10 15032 1316  896 R  2.0  0.0   0:00.01 top
    1 root      20   0 19364 1472 1164 S  0.0  0.0   1:11.58 init
    2 root      20   0     0    0    0 S  0.0  0.0   0:00.00 kthreadd
    3 root      RT   0     0    0    0 S  0.0  0.0   0:14.67 migration/0
    4 root      20   0     0    0    0 S  0.0  0.0   1:57.13 ksoftirqd/0
Where the 'S' columns shows 's' for Sleep, for most processes
okay thanks...i see the same thing on my linux servers...
