Cisco Wireless Controller
TDoan
Level 3
Level 3
Hi All,
I would like develop the interface to enable in-room billing for internet. I would like to ask you.
What communication protocol do i use to connect to Cisco Wireless Controller?
Do you have any interface specification Cisco Wireless Controller to third party?
Please advise...
Thanks & regards
Thuy Doan
dhook
Level 3
Level 3
This question is in the wrong forum, but anyway... The WLC's support SNMP for configuration. Thats how Cisco Prime configure them as well. I do believe you will find most of what you need in the AIRESPACE MIB.
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=AIRESPACE-WIRELESS-MIB
Thanks for your answer.
Thuy Doan
