Create device using Device Template via AXL
mgowland
Level 2
Level 2
Is it possible to add a device in AXL which copies the default values from a custom device template?
dstaudt
There is no 'copy' functionality, or 'create a new phone using this template', however it looks like you can retrieve Phone Templates via <getPhone>.  Your app would then need to parse the relevant attributes from the result XML, then create an <addPhone> request...
dstaudt
