CUCM Get user status for users using AXL APIs
Is it possible to get user status for users that is shown on the dashboard from the AXL APIs? I have tried checking the APIs, get user, list user and also tried SQL queries but none of them have that information.
Image is attached for reference to user status.
thank you
I checked that field it doesn't return the status that is on the dashboard. The dashboard status is user status and has values like Enabled Local User, LDAP Active User and so on while the status gotten from the get User API is a number and is same for all.
thedd
Just tryed myself
SQL: run sql select userid, status from enduser
userid     status
LDAP_USER   1
INAKT_USER  2
AXl get User says <status>1</status> or <status>2</status>
Status 1 seems to be Active Enabled LDAP Synchronized User
Status 2 seems to be Inactive LDAP Synchronized User
So i had a look in the Data Dictionary:
2.3.175.41 status (FI-1653)
Type: long
Default Value: 1
Remarks: Active or Inactive
As far as i see there are only the two states active or inactive
If you want to know if auser is LDAP Synced you will need to have a look for fkdirectorypluginconfig
run sql select userid, status, fkdirectorypluginconfig from enduser
userid        status    fkdirectorypluginconfig
LDAP_USER       1       444cfb4a-ab21-9519-9f92-99144c530f59
LOKAL_USER      1       NULL
INAKT_USER      2       444cfb4a-ab21-9519-9f92-99144c530f59
fkdirectorypluginconfig is null if there is no LDAP refernece and will return the ID of the LDAP if synced from there
