Finding actively logged in device profiles
shikamarunara
Level 4
Level 4
     I'm writing a query to find out if a phone has been logged into with extension mobility.  I've written the following, but I doubt it has enough information to do what I need and will likely create a join;
select * from Device where tkDeviceProfile != '0' and tkDeviceProfile != '3' and tkDeviceProfile != '4'
This will give me the full list of device profiles, but nothing about their state or which phone is using it.  Can someone tell me where the states are kept?
dstaudt
Take a look at the extensionmobilitydynamic table:
https://developer.cisco.com/site/axl/documents/latest-version/datadictionary11-0-1.gsp
Also the Extension Mobility API, which makes it pretty easy to query this kind of info:
Cisco DevNet: Extension Mobility API (EMAPI)
dstaudt
Hi dstaudt,
     Thank you for replying.  Just making sure I'm understanding the table properly based on the database dictionary; the two fields that look like I would be primarily interested in are fkdevice and fkdevice_currentloginprofile.  These two fields contain the uuid of the phone that's logged into (if it's logged into), and the uuid of the device profile being used?
I believe that's right
Thanks again, much appreciated.
