GetLine (dn + partition) of a device of a specific userid using AXL SQLquery API
I have successfully got the lines for all the devices in CUCM using the following AXL SQLQuery:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.0">
   <soapenv:Header/>
       <soapenv:Body>
          <ns:executeSQLQuery>
             <sql>select d.name,d.description,n.dnorpattern as DN,rp.name as partition
                from device as d
                inner join devicenumplanmap as dmap on dmap.fkdevice=d.pkid
                inner join numplan as n on dmap.fknumplan=n.pkid
                inner join routepartition as rp on n.fkroutepartition=rp.pkid
                where d.tkclass=1
                order by d.name</sql>
          </ns:executeSQLQuery>
       </soapenv:Body>
</soapenv:Envelope>
Now, what I failed doing, is running this query agains a specific userid. So, somewhere in the query I would like to get, instead of all the lines for all the devices, a line for a device that belongs to a specific user.
Is there any way that I could do this using AXL API ?
dstaudt
As a possible hint, the relationship between the user and the device is stored in 'enduserdevicemap'.  You can probably add another join on 'device.pkid = enduserdevicemap.fkdevice' and 'enduser.pkid = enduserdevicemap.fkuser'
Note, the table uses the user's PKID/uuid in the 'fkenduser' field (not the 'user ID'), so you may need to retrieve the user's PKID/uuid first, i.e. via <listUser> or <getUser>.
