getSNMPCommunityString
Cole.Aten
Good Afternoon,
I am attempting to gather some configuration details from CUCM via AXL. I have the following request, pulled from SOAPUI:
request='<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.0">
   <soapenv:Header/>
   <soapenv:Body>
      <ns:getSNMPCommunityString sequence="?">
         <communityName>?</communityName>
      </ns:getSNMPCommunityString>
   </soapenv:Body>
</soapenv:Envelope>'
I am posting using the following:
curl --silent -k -u 'XXXXXXXX:YYYYYYYY' -H 'SOAPAction: CUCM:DB ver=8.0 getSNMPCommunityString' -H "Content-type: text/xml;" -d "$request" "https://X.X.X.X/axl/"
My response appears to be hitting the appropriate endpoint, but nothing it doesn't seem to find any community strings, even though there are some configured:
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
  <soapenv:Body>
    <soapenv:Fault>
      <faultcode>soapenv:Server</faultcode>
      <faultstring>Community String Name Not Found</faultstring>
      <detail>
        <axlError>
          <axlcode>5003</axlcode>
          <axlmessage>Community String Name Not Found</axlmessage>
          <request>getSNMPCommunityString</request>
        </axlError>
      </detail>
    </soapenv:Fault>
  </soapenv:Body>
</soapenv:Envelope>
Any help would be greatly appreciated.
Thanks!
dstaudt
<getSNMPCommunityString> is provided for retrieving details of a single (known) community string, e.g.:
   <soapenv:Body>
      <ns:getSNMPCommunityString>
         <communityName>testSnmpCommunityString</communityName>
   </soapenv:Body>
</soapenv:Envelope>
   <soapenv:Body>
      <ns:getSNMPCommunityStringResponse xmlns:ns="http://www.cisco.com/AXL/API/10.5">
         <return>
            <SNMPCommunityString>
               <version>both</version>
               <accessPrivilege>ReadWriteNotify</accessPrivilege>
               <ArrayOfHosts/>
            </SNMPCommunityString>
         </return>
      </ns:getSNMPCommunityStringResponse>
   </soapenv:Body>
</soapenv:Envelope>
There does not appear to be a corresponding <listSNMPCommunityString> request, unfortunately, for searching/listing for community strings.  It may be possible to retrieve such a list from the CUCM database via the <executeSqlQuery> request, if you can figure out which tables/fields in the database contain the data.  I could not figure out which tables after about a 45 min exploration - it's possible the SNMP config data is not in the DB, and is stored elsewhere on the system...
