How to enable Native emergency location via AXL
I was wondering if there was a way via AXL (or sqlExecute cmd) to enable Emergency Location (ELIN) Support in CUCM? basically checking the box under Call Routing > Emergency Location > Emergency Location Configuration
thanks,
Sebastien Michelet
Anusha B R
Hi Sebastien,
I believe there is no direct AXL API to enable Emergency Location, but you can definitely achieve it through "executeSQLQuery" API if you know the table name. HTH!
Anusha B R
