PowerShell SOAP Request answered with "error.validation.required"
I am trying to retrieve the backup progress via SOAP in PowerShell.
Here my code:
$serverURL = 'https://auc521/platform-services/services/MaintenanceService?wsdl'
$soapRequest = [xml]@"
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ser="http://services.api.platform.vos.cisco.com">
   <soapenv:Header/>
   <soapenv:Body>
      <ser:getBackupProgress/>
   </soapenv:Body>
</soapenv:Envelope>
$ciscoUser = 'admin'
$ciscoPwd = 'UC123456!'
$header = @{"Authorization" = "Basic "+[System.Convert]::ToBase64String([System.Text.Encoding]::UTF8.GetBytes($ciscoUser+":"+$ciscoPwd))}
$result = Invoke-WebRequest -Uri $serverURL -Headers $header -Method Post -Body $soapRequest -ContentType "text/xml"
$SOAP = $result.Content
$SOAP | Out-File -FilePath $logFile
The response I get is the following:
<?xml version='1.0' encoding='UTF-8'?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
  <soapenv:Body>
    <ns:getBackupProgressResponse xmlns:ns="http://services.api.platform.vos.cisco.com">
      <ns:return xmlns:ax214="http://api.platform.vos.cisco.com/xsd" xmlns:ax213="http://element.services.api.platform.vos.cisco.com/xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ax213:MaintenanceResponse">
        <ax213:remoteMessages xsi:type="ax213:RemoteMessage">
          <ax214:error>true</ax214:error>
          <ax214:info>false</ax214:info>
          <ax214:messageKey>error.validation.required</ax214:messageKey>
          <ax214:messageType>internal.message.error</ax214:messageType>
          <ax214:warning>false</ax214:warning>
          <ax213:messageParams>wsa.replyto</ax213:messageParams>
        </ax213:remoteMessages>
        <ax213:result>internal.request.failed</ax213:result>
        <ax213:backupProgressResult xsi:nil="true" />
        <ax213:startBackupResult xsi:nil="true" />
        <ax213:updateScheduleResult xsi:nil="true" />
      </ns:return>
    </ns:getBackupProgressResponse>
  </soapenv:Body>
</soapenv:Envelope>
Can you please help me to fix it?
Thanks in advance
Ruben
dstaudt
It looks like the WS-Addressing info (which is required for PAWS requests) has not been included in the request XML.  See the developer guide for more details: https://developer.cisco.com/site/paws/documents/api-reference/#web-service-addressing
This request seems to work on my 10.5 lab system:
POST https://ds-ucm105.cisco.com:8443/platform-services/services/MaintenanceService.MaintenanceServiceHttpsSoap12Endpoint/ HTTP/1.1
Accept-Encoding: gzip,deflate
Content-Type: application/soap+xml;charset=UTF-8;action="urn:getBackupProgress"
Content-Length: 634
Host: ds-ucm105.cisco.com:8443
Connection: Keep-Alive
User-Agent: Apache-HttpClient/4.1.1 (java 1.5)
Authorization: Basic QWRtaW5pc3RyYXRvcjpjaXNjb3BzZHQ=
<?xml version="1.0" encoding="UTF-8"?>
<soap:Envelope xmlns:soap="http://www.w3.org/2003/05/soap-envelope" xmlns:ser="http://services.api.platform.vos.cisco.com">
  <soap:Header xmlns:wsa="http://www.w3.org/2005/08/addressing">
    <wsa:Action>urn:getBackupProgress</wsa:Action>
    <wsa:ReplyTo>
      <wsa:Address>http://www.w3.org/2005/08/addressing/anonymous</wsa:Address>
    </wsa:ReplyTo>
    <wsa:MessageID>uuid:dc75e529-34fb-4009-b594-d801ec86f39e</wsa:MessageID>
  </soap:Header>
  <soap:Body>
  </soap:Body>
</soap:Envelope>
Thank you for the fast feedback :-)
I exchanged the variable content as suggested. My lines look as follows:
    <wsa:ReplyTo>
    </wsa:ReplyTo>
  </soap:Header>
  <soap:Body>
  </soap:Body>
</soap:Envelope>
The response I get is: The remote server returned an error: (500) Internal Server Error.
The XML portion seems to work copy/pasting and executing with soapUI for me against CUCM 10.5:
- Are you able to successful do a similar request using another tool (soapUI) or mechanism?
- Can you confirm the PAWS service is enabled on CUCM? Getting Started
- Can you capture the raw HTTP request, either somehow via power tools script, or by using something like Fiddler2?
Just downloaded Fiddler2 and could enable the SSL decryption! - Great hint! :-)
Here is the TextView:
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Header xmlns:wsa="http://www.w3.org/2005/08/addressing"><wsa:Action>http://www.w3.org/2005/08/addressing/soap/fault</wsa:Action></soapenv:Header><soapenv:Body><soapenv:Fault><faultcode>soapenv:VersionMismatch</faultcode><faultstring>Transport level information does not match with SOAP Message namespace URI</faultstring><detail><Exception>org.apache.axis2.AxisFault: Transport level information does not match with SOAP Message namespace URI
</Exception></detail></soapenv:Fault></soapenv:Body></soapenv:Envelope>
Found than that changing the content type to: application/soap+xml works!!!
Thank you very much!
Kind regards
Ruben
