Python CUCM 10.5 AXL updateLine
glen.cobby
Frequent Visitor
Frequent Visitor
Hi All,
I am using Python with suds-jerko. I can add a new DN ok, however I need to add an Enterprise Alternate number, looking at the element for update line, I can see I either need the uuid of the line or use pattern and route partition. I have tried both, and I either get Type not found: 'uuid' or Type not found 'pattern'.
Here is the code I am sending for the UUID -
result = cucm_server.service.updateLine({'UUID':addedlinepkid,
                                           'enterpriseAltNum' : [{'numMask':shortdial,'addLocalRoutePartition':'t','routePartition':routepartitionpkid}]
I have also tried
result = cucm_server.service.updateLine({'pattern':e164dn,'routePartitionName':routepartitionname,
Has anyone get a working example of a line update using Python? Or can see anything wrong with my code above?
Glen
dstaudt
This took entirely too long for a "helper" library   This is what I came up with:
ean = {
    "numMask": "8XXXX",
    "isUrgent": True,
    "addLocalRoutePartition": True,
    "routePartition": "testPartition"
result = client.service.updateLine(
    pattern = "5555",
    routePartitionName = "",
    description = "test description",
    useEnterpriseAltNum = True,
    enterpriseAltNum = ean
Full running script below:
# Installing a root/CA Certificate
# (Tested on Ubuntu 16.10)
# Retrieve certificate from CUCM
#    - openssl s_client -showcerts -connect cucm-node.example.com:443 </dev/null 2>/dev/null|openssl x509 >cucm-node.example.com.crt
# Store certificate on the client
#    - Create a directory for extra CA certificates in /usr/share/ca-certificates:
#        sudo mkdir /usr/share/ca-certificates/extra
#    - Copy the CA .crt file to this directory:
#        sudo cp foo.crt /usr/share/ca-certificates/extra/foo.crt
#    - Append the certificate path (relative to /usr/share/ca-certificates) to /etc/ca-certificates.conf
#        sudo dpkg-reconfigure ca-certificates
# In case of a .pem file, it must first be converted to a .crt file:
#    openssl x509 -in foo.pem -inform PEM -out foo.crt
from suds.client import Client
# import logging
# logging.basicConfig(level=logging.INFO)
# logging.getLogger("suds.transport").setLevel(logging.DEBUG)
client = Client("file:///home/dstaudt/Documents/AXL/v10.5(1)/axlsqltoolkit/schema/10.5/AXLAPI.wsdl",
    location="https://ds-ucm105.cisco.com/axl/",
    username="Administrator",
    password="ciscopsdt")
newLine = {
        "pattern" : "5555",
        "routePartitionName": ""
result = client.service.addLine(newLine)
ean = {
    "numMask": "8XXXX",
    "isUrgent": True,
    pattern = "5555",
