Save configuration using NX API
Tom22
Visitor
We are currently using the NX-API to create NBM flows on a Cisco switch, which is working fine. Now we would like to save these flows to the startup config. Is this also something that can be done with NX-API?
Switch model:
Cisco Nexus N9K-C93180YC-FX
@Tom22 this should help https://developer.cisco.com/docs/nx-os-n3k-n9k-api-ref-7-x/#!copy-running-config-startup-config
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
