Using AXLAPIServiceStub.java
Martin Sloan
Level 2
Level 2
After generating AXLAPIServiecStub.java from the AXLAPI.wsdl file, I can't open it within Eclipse or IntelliJ as they either freeze or state the file is too large, respectively.  Has anyone run into this issue and have a workaround or suggestion for opening the stub classes in an IDE?
dstaudt
Increasing the amount of memory available to the IDE/Java may help:
FAQ How do I increase the heap size available to Eclipse? - Eclipsepedia
Thanks for the reply.  It's maxed at 8GB.  Opening the file pegs the memory and freezes Eclipse.
