VB code - issue with returned data from AXL/SOAP listLine
John Watkins
Level 2
Level 2
Hello, and thank you for looking at this!
I have the following code I'm executing against CUCM 11.5.1 AXL SOAP. I get the Reponse as  <line uuid="{0395BCFF-18F9-00FE-0015-C037F977F08A}"><description>John Watkins (Jrwatkins)</description><routePartitionName uuid="{313DD3B9-CA80-4793-9D9F-F606D1A5F0E9}">INTERNAL-PT</routePartitionName></line>. However, I never get the Associated Devices.....
----Code Snippit-----
Function ListLine(strName As String) As String
        Dim strPostData As String
        Dim strPostReturn As String
        strPostData = strSOAPHeader & "<ns:listLine sequence=""?"">
         <searchCriteria>
             <pattern>" & strName & "</pattern>
            <routePartitionName>INTERNAL-PT</routePartitionName>
         </searchCriteria>
         <returnedTags ctii=""?"" uuid=""?"">
              <associatedDevices>
                <device></device>
             </associatedDevices>
              <routePartitionName uuid=""?""/>
             <description/>
             </returnedTags>
      </ns:listLine>" & strSOAPFooter
        strPostReturn = GetDataFromURL(strUCMAXLURL, "POST", strPostData, strUCMbase64creds)
        Return strPostReturn
    End Function
/----Code Snippit-----
----Request
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/11.0">
                                      <soapenv:Header/>
                                      <soapenv:Body><ns:listLine sequence="?">
         <searchCriteria>
             <pattern>%12065551000</pattern>
         </searchCriteria>
         <returnedTags ctii="?" uuid="?">
              <associatedDevices>
                <device></device>
              <routePartitionName uuid="?"/>
             <description/>
             </returnedTags>
      </ns:listLine>   </soapenv:Body>
</soapenv:Envelope>
/---EndRequest
----Response
/----Response
dstaudt
I can confirm this behaviour on my 10.5 and 11.5 systems, and have opened defect CSCvc79941 for tracking.  As a workaround, it should be possible to use <executeSqlQuery> to retrieve device->line association information, for example:
<?xml version="1.0" encoding="UTF-8"?>
<soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
  <soap:Body>
    <ns:executeSQLQuery xmlns:ns="http://www.cisco.com/AXL/API/11.5">
      <sql xsi:type="xsd:string">select device.name from device, devicenumplanmap, numplan
        where device.pkid = devicenumplanmap.fkdevice and numplan.pkid = devicenumplanmap.fknumplan
        and numplan.dnorpattern = "1000"</sql>
    </ns:executeSQLQuery>
  </soap:Body>
</soap:Envelope>
