10-06-2016 03:59 AM
I've made the Eclipse-Java/GetPhone example and when I run it on my MacOSX-10.11.6 Eclipse I'll get the following results:
2016-10-05 15:08:15,339 [main] INFO Demo.informUser:108 - Welcome to the Cisco AXL Sample APP.
2016-10-05 15:08:15,339 [main] WARN Demo.getPhoneInfo:77 - Enter AXLAPIService ...
2016-10-05 15:08:15,340 [main] DEBUG AXLAPIService.<clinit>:32 - baseUrl=file:/Users/NLverseveldO/Documents/Workspaces/ws_eclipse/Cisco_axl-demo/bin/com/cisco/axlapiservice/
2016-10-05 15:08:15,341 [main] DEBUG AXLAPIService.<clinit>:34 - url=file:/Users/NLverseveldO/Documents/Workspaces/ws_eclipse/Cisco_axl-demo/schema/current/AXLAPI.wsdl
2016-10-05 15:08:15,680 [main] WARN Demo.getPhoneInfo:79 - GetAXLPort ...
2016-10-05 15:08:20,721 [main] INFO Demo.getPhoneInfo:84 - validatorUrl=https://ccm-10-5-1.ascom-rd.com:8443/axl/
2016-10-05 15:08:20,721 [main] WARN Demo.getPhoneInfo:85 - Setup up getRequestContext() ...
2016-10-05 15:08:20,723 [main] WARN Demo.getPhoneInfo:91 - Create GetPhoneReq instance ...
2016-10-05 15:08:20,723 [main] DEBUG Demo.getPhoneInfo:94 - Set-up axlParams: com.cisco.axl.api._8.GetPhoneReq@508f66bd
2016-10-05 15:08:20,723 [main] DEBUG Demo.getPhoneInfo:96 - Performing getPhone request ...
2016-10-05 15:08:22,424 [main] INFO Demo.informUser:108 - Requested info for phone: SEP4C00828573D8 returned: Cisco 7925
where the time between GetAXLPort and the GetPhoneReq takes about 5 seconds, whereas when I run the same example on an (embedded) open-idk.vm I'll get the following results:
2016-10-05 14:23:38,478 [Thread-3] INFO Demo.informUser:108 - Welcome to the Cisco AXL Sample APP.
2016-10-05 14:23:38,505 [Thread-3] WARN Demo.getPhoneInfo:77 - Enter AXLAPIService ...
2016-10-05 14:24:16,144 [Thread-3] WARN Demo.getPhoneInfo:79 - GetAXLPort ...
2016-10-05 14:44:49,836 [Thread-3] INFO Demo.getPhoneInfo:84 - validatorUrl=https://ccm-10-5-1.ascom-rd.com:8443/axl/
2016-10-05 14:44:49,908 [Thread-3] WARN Demo.getPhoneInfo:85 - Setup up getRequestContext() ...
2016-10-05 14:44:49,929 [Thread-3] WARN Demo.getPhoneInfo:91 - Create GetPhoneReq instance ...
2016-10-05 14:44:49,939 [Thread-3] DEBUG Demo.getPhoneInfo:94 - Set-up axlParams: com.cisco.axl.api._8.GetPhoneReq@c0c9c4
2016-10-05 14:44:49,947 [Thread-3] DEBUG Demo.getPhoneInfo:96 - Performing getPhone request ...
2016-10-05 14:44:56,929 [Thread-3] INFO Demo.informUser:108 - Requested info for phone: SEP4C00828573D8 returned: Cisco 7925
where the time between GetAXLPort and the GetPhoneReq takes a whopping 22 minutes!??
Does anybody know have an idea where this delay comes from or have a solution how to speed this up?
I also tried multiple testruns with about the same timing-results, e.g. about 5 seconds while running native on OSX and about 22 minutes while running 'embedded'?
Any advice or help, very much appreciated, thanks in advance.
Solved! Go to Solution.
10-10-2016 02:36 AM
Hi 'dstaudt', thanks for the great suggestions!
I completely forgot that my test/host-OS has a 2.2Ghz Intel Core i7 with 16 GB-RAM, and the embedded environment is running on a 400 Mhz Atmel with 256 MB-RAM, which might explain the differences in duration.
I'm working on a version with XML over HTTP but encounter some certificate issues. I've to figure out how to use either a HttpsUrlConnection or HttpClient / HttpPost connection and I've to ignore all certificates or download / convert the Cisco.cer to a (java)keystone.jks file in my project(s).
The GetPhoneReq() example seems to work only with https i.s.o. http (I tested this with SoapUI).
10-06-2016 02:06 PM
As you have probably noticed the AXL WSDL is really big
As a result, the native code libraries generated by WSDL compilers is pretty gigantic, and may take a long time to initialize - especially on constrained systems (like an embedded device.)
A few workarounds I might suggest:
- Skip the WSDL->code compilation part altogether, and just treat the API as XML over HTTP. I.e. build up the XML request objects using an XML DOM object/library, or just via string concatenation - parsing the result similarly. This can be extremely lightweight and efficient compared to the whole SOAP abstraction overhead.
- Go into the WSDL and remove the parts that your application doesn't use (typically apps only use a handful of the many hundreds of possible requests) - resulting in a vastly smaller generated code output. Note this requires you to have a bit of understanding of WSDL itself so as to know how to safely elide parts of it
- Simiarly, you can remove un-used portions of the generated code library
10-10-2016 02:36 AM
10-18-2016 06:18 AM
Hi 'dstaudt' again. Thanks to your great suggestions I got a working version. I based my solution on the AXL-HelloWorld example and used code to ignore all certificates! On my embedded environment the GetPhone() call now takes a whopping 1.6 seconds i.s.o. 22 minutes! You're me hero of the month and thanks again for your time.
10-20-2016 08:55 AM
Awesome, and thanks for the update!
