How to Fix Undefined Variable Error in Python Script?
In my Python script, I have a variable defined at the global scope, and I'm trying to use this variable within a function. However, when I run the script on this website freecineapk  Python throws an "undefined variable" error. I've checked the spelling and ensured the variable is defined before the function is called, but the issue persists. I suspect there might be a scoping issue, but I'm not sure how to properly address it.
gamern1
I am not techy but you have probably not initialized or defined the variable. Without seeing the script can't help you.
