Mobile Applications
Discussions, knowledge articles and more
Activity in Mobile Applications
Windows Server 2022 on UCS e0140D
Hi Guys,I have managed to install Win Server 2022 on UCS e-140D that I sourced from ebay. It came with one SAS drive, I installed a solid state drive lying around and installed OS on that. However, after reboot its not able to find that drive, but if...
dban7 by Frequent Visitor
  • 2369 Views
  • 1 replies
Proximity can't use the microphone
Hi!I can't connect to our projection systems via Proximity. Proximity says 'Finding video systems' then reports 'Your microphone is not working'. The problem is specific to one computer as my old compute worked without any issues and other computer a...
primoz by Community Member
  • 4600 Views
  • 3 replies
"Cloud Proximity Guest Share" setting & disable guest share?
I found this setting under Webex on a Webex Room Kit Pro. You can set "Cloud Proximity Guest Share" to Auto or to Off. What happens if you set it to off? No Proximity share possible from a Webex client? Is there a way to disable or limit Webex Proxim...
gfolens by Level 7
  • 4552 Views
  • 3 replies
Important Update: Discontinuation of Cisco Proximity
Dear Valued Customers,we wish to inform you of an important update regarding Cisco Proximity. As part of our ongoing product lifecycle management and commitment to providing high-quality solutions, Cisco has made the strategic decision to discontinue...
Proximity - searching for room endlessly
Hello,We are experiencing issues with Proximity app when attempting to connect to the Cisco Webex Room Kits. Recently, the app has been stuck in a loop, alternating between searching for the Room Kit and displaying an error (indicated by a red microp...
anze-grcar by Community Member
  • 2811 Views
  • 1 replies
Proximity - Remove 'Could not verify device identity'
Hello,we currently have room bars set up in meeting room and are looking to implement Proximity.However I get a message that I need to accept when my laptop connects to the room bar over Proximity.The message states 'Could not verify device identity....
mrjelly by Level 5
  • 2460 Views
  • 1 replies
Mobile Challenge Contest Rules
“Mobile Challenge” Contest Official RulesNO PURCHASE NECESSARY TO ENTER OR WIN.  A PURCHASE WILL NOT INCREASE YOUR CHANCES OF WINNING.  VOID WHERE PROHIBITED OR RESTRICTED. This Contest (the "Contest") opens on February 11th, 2013 with a new challeng...
Resolved! Need Information About Build A Application
Hello Everyone Basically I Am the Writer In News Channel 23 science I Want to Know That Through My Thread I Want To Crate A Application For My News Channel 23 Science Is Cisco can Help Me About To Create A Application For Me Is cisco Provide Any Serv...
yamanchugh by Community Member
  • 3094 Views
  • 2 replies
