ADFS SSO Configuration using Metadata file
mohammedb1
Quite frequently there is a need to setup multi-tenancy with SSO integration.
When logging into the Vendor Admin section within CloudCenter, select Vendor Authentication Settings from the Action list drop-down menu.
It is useful to use the IDP Metadata URL to establish the mutual trust between the CloudCenter platform and the IDP provider, which currently only supports HTTP, (HTTPS is not supported).
If the IDP solution does not support HTTP Metadata URL, then it is useful to use the 'IDP Metadata File' option.
This IDP Metadata File field is case sensitive, after the appropriate fields are populated with the relevant information, press the 'Update button' if updating the existing configuration or Download SP MetaData option to provide to the IDP provider.
The Metadata file for CloudCenter is created and stored in the following path of the CCM component within CloudCenter  /usr/local/osmosix/metadata/sp
However it is crucial to copy the IDP metadata file provided by the IDP to the following path in the CCM component of CloudCenter /usr/local/osmosix/apps
This should then allow SSO to work successfully without the need for a MetaData URL.
0 Replies 0
