AAA acls on FWSM
gseiler
Hi, my customer has a problem on a FWSM 2.3.3.2.
He uses a script to manage his acls.
access-l mode manual
no access-l inside_auth_acl
access-l inside_auth_acl deny <whatever_to_deny >
access-l inside_auth_acl permit ip any any
access-l commit
After manual committing an AAA acl the acl is not effective anymore, it is disabled and not working, only after re-apply the statement "aaa authentication match...." it is working again.
CCO states that authentication acls are always commited automatically and manual commit does not work.
But does this mean that when doing manual commit, the acl becomes disabled and has to be re-applied again.Customer claims that this was ok with 2.3.1.3.
Now the question is if this is a bug or working as designed.
Regards Guenther
mchin345
Level 6
Level 6
To further look into this problem, can you send me the output of show tech and a full example of what changes are made?. Can you also send the console output if received that indicates that the access-list is "disabled".
