AAA authorization problem
spanglenuts
Community Member
I have the following config on my switch...
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login CONSOLE line
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 10 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
The problem is that when I log into the switch via console port, and I enter these commands in, I instantly get "Command Authorization Failed" on any commands there after. It's mind boggling because there is no possible way the switch is talking to my Cisco ACS. I didn't even put in the tacacs-server key. I'm being forced to reboot the box each time. What am I missing?
Thank you for your time. I'm using IOS Version 12.2(25)SEB4.
-Andrew
3 Accepted Solutions
chaitu_kranthi
Level 4
Level 4
Before doing the tacacs configuration create one local user.
add the following commands.
username cisco password cisco
aaa new-model
tacacs-server host x.x.x.x
tacacs-server key ........
please score me if it help to you
As per my concern those commands are enough.
Jagdeep Gambhir
Level 11
Level 11
Andrew,
What you are getting is not a expected behavior. By default Command authorization is disabled on console port, so from console session it should not check for any authorization.
To enable it we need to use a hidden command on IOS aaa authorization console
It seems that you have not issued that command but still it is checking for the authorization.
This seems that we are hitting a bug here. Please check these bug CSCeb08860 & CSCsg74428.
Pls consider upgrade or apply a work around described in bug.
~JG
chaitu_kranthi
Level 4
Level 4
aaa new-model
Just so I'm clear, After I create a user account, should I only do the commands that you listed, or can I do all of my commands?
I'll make sure to score ya.
Andrew
Jagdeep Gambhir
Level 11
Level 11
Andrew,
~JG
