AAA Fallback to local for PPP does not work!!!
antonov.a
Community Member
AAA fallback to local doesn't work!
IOS 152-4.M4
What's wrong? Please help!
CONFIG:
aaa new-model
aaa group server radius radiussrv-group
server 10.100.2.41
server 10.100.2.42
aaa authentication login default group radiussrv-group local
aaa authentication login aaa-list group radiussrv-group local
aaa authentication login aaa-list-console local
aaa authentication ppp default group radiussrv-group local
aaa authorization console
aaa authorization exec aaa-list group radiussrv-group local
aaa authorization exec aaa-list-console if-authenticated
aaa authorization network default group radiussrv-group local
aaa accounting exec aaa-list
action-type start-stop
aaa accounting exec aaa-list-console
aaa attribute list ListName_grbsurm
attribute type addr 172.31.10.3 service ppp protocol ip mandatory
attribute type dns-servers "10.100.2.10"
attribute type dns-servers "10.100.2.11"
aaa attribute list ListName_pbsurm
attribute type addr 172.31.10.4 service ppp protocol ip mandatory
aaa attribute list ListName_websvod
attribute type addr 172.31.10.5 service ppp protocol ip mandatory
username local_admin privilege 15 secret 123123123
username grbsurm password 123123123
username grbsurm aaa attribute list ListName_grbsurm
username pbsurm password 123123123
username pbsurm aaa attribute list ListName_pbsurm
username svodweb password 123123123
username svodweb aaa attribute list ListName_websvod
interface Group-Async0
description ===== GROUP_MODEM =====
ip unnumbered Loopback0
ip access-group 111 in
encapsulation ppp
ip tcp header-compression
ip policy route-map DIAlUP-TO-ASA
peer default ip address pool dialin
async mode interactive
no keepalive
compress stac
ppp authentication ms-chap-v2
group-range 0/451 0/486
radius-server host 10.100.2.41 key 123123123
radius-server host 10.100.2.42 key 123123123
line 0/451 0/486
modem InOut
modem autoconfigure discovery
transport input ssh
autoselect during-login
autoselect ppp
DEBUG OUT:
2013-07-05 10:17:53          Local7.Notice          172.30.255.8          379: Jul  5 03:17:51.999: %PARSER-5-CFGLOG_LOGGEDCMD: User:bms  logged command:aaa authentication ppp default local
2013-07-05 10:17:54          Local7.Notice          172.30.255.8          380: Jul  5 03:17:53.567: %SYS-5-CONFIG_I: Configured from console by bms on vty0 (193.232.38.2)
2013-07-05 10:19:06          Local7.Info          172.30.255.8          381: Jul  5 03:19:04.803: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3832101030 N/A
2013-07-05 10:19:31          Local7.Debug          172.30.255.8          382: Jul  5 03:19:31.083: TTY0/452: timer_create_bg error
2013-07-05 10:19:32          Local7.Error          172.30.255.8          383: Jul  5 03:19:31.587: %LINK-3-UPDOWN: Interface Async0/452, changed state to up
2013-07-05 10:19:34          Local7.Info          172.30.255.8          384: Jul  5 03:19:32.839: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 3832101030 , call lasted 28 seconds
2013-07-05 10:19:35          Local7.Notice          172.30.255.8          385: Jul  5 03:19:34.323: %LINK-5-CHANGED: Interface Async0/452, changed state to reset
2013-07-05 10:19:40          Local7.Error          172.30.255.8          386: Jul  5 03:19:39.323: %LINK-3-UPDOWN: Interface Async0/452, changed state to down
2013-07-05 10:21:28          Local7.Notice          172.30.255.8          387: Jul  5 03:21:27.155: %SYS-5-CONFIG_I: Configured from console by bms on vty1 (193.232.38.2)
2013-07-05 10:22:44          Local7.Info          172.30.255.8          388: Jul  5 03:22:42.798: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3832101030 N/A
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          389: Jul  5 03:23:08.010: TTY0/463: timer_create_bg error
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          390: Jul  5 03:23:08.510: As0/463 PPP: Fast Starting
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          391: Jul  5 03:23:08.510: As0/463 PPP: Processing FastStart message
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          392: Jul  5 03:23:08.510: PPP: Alloc Context [1E12B3C]
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          393: Jul  5 03:23:08.510: ppp3 PPP: Phase is ESTABLISHING
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          394: Jul  5 03:23:08.510: ppp3 PPP: Using AAA Unique Id = 13D
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          395: Jul  5 03:23:08.510: As0/463 PPP: Authorization required
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          396: Jul  5 03:23:08.510: As0/463 PPP: Using modem call direction
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          397: Jul  5 03:23:08.510: As0/463 PPP: Treating connection as a callin
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          398: Jul  5 03:23:08.510: As0/463 PPP: Session handle[CA000003] Session id[3]
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          399: Jul  5 03:23:08.510: As0/463 LCP: Event[OPEN] State[Initial to Starting]
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          400: Jul  5 03:23:08.510: As0/463 PPP LCP: Enter passive mode, state[Stopped]
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          401: Jul  5 03:23:08.510: As0/463 LCP: I CONFREQ [Stopped] id 0 len 23
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          402: Jul  5 03:23:08.510: As0/463 LCP:    ACCM 0x00000000 (0x020600000000)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          403: Jul  5 03:23:08.510: As0/463 LCP:    MagicNumber 0x020725BB (0x0506020725BB)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          404: Jul  5 03:23:08.510: As0/463 LCP:    PFC (0x0702)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          405: Jul  5 03:23:08.510: As0/463 LCP:    ACFC (0x0802)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          406: Jul  5 03:23:08.510: As0/463 LCP:    Callback 6 (0x0D0306)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          407: Jul  5 03:23:08.510: As0/463 LCP: O CONFREQ [Stopped] id 1 len 25
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          408: Jul  5 03:23:08.510: As0/463 LCP:    ACCM 0x000A0000 (0x0206000A0000)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          409: Jul  5 03:23:08.510: As0/463 LCP:    AuthProto MS-CHAP-V2 (0x0305C22381)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          410: Jul  5 03:23:08.510: As0/463 LCP:    MagicNumber 0xD479EC40 (0x0506D479EC40)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          411: Jul  5 03:23:08.510: As0/463 LCP:    PFC (0x0702)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          412: Jul  5 03:23:08.510: As0/463 LCP:    ACFC (0x0802)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          413: Jul  5 03:23:08.510: As0/463 LCP: O CONFREJ [Stopped] id 0 len 7
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          414: Jul  5 03:23:08.510: As0/463 LCP:    Callback 6 (0x0D0306)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          415: Jul  5 03:23:08.510: As0/463 LCP: Event[Receive ConfReq-] State[Stopped to REQsent]
2013-07-05 10:23:08          Local7.Error          172.30.255.8          416: Jul  5 03:23:08.514: %LINK-3-UPDOWN: Interface Async0/463, changed state to up
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          417: Jul  5 03:23:08.514: As0/463 PPP: Sending cstate UP notification
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          418: Jul  5 03:23:08.514: As0/463 PPP: Processing CstateUp message
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          419: Jul  5 03:23:08.710: As0/463 PPP: I pkt type 0xC021, datagramsize 29 link[ppp]
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          420: Jul  5 03:23:08.710: As0/463 LCP: I CONFACK [REQsent] id 1 len 25
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          421: Jul  5 03:23:08.710: As0/463 LCP:    ACCM 0x000A0000 (0x0206000A0000)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          422: Jul  5 03:23:08.710: As0/463 LCP:    AuthProto MS-CHAP-V2 (0x0305C22381)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          423: Jul  5 03:23:08.710: As0/463 LCP:    MagicNumber 0xD479EC40 (0x0506D479EC40)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          424: Jul  5 03:23:08.710: As0/463 LCP:    PFC (0x0702)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          425: Jul  5 03:23:08.710: As0/463 LCP:    ACFC (0x0802)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          426: Jul  5 03:23:08.710: As0/463 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          427: Jul  5 03:23:08.730: As0/463 PPP: I pkt type 0xC021, datagramsize 24 link[ppp]
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          428: Jul  5 03:23:08.730: As0/463 LCP: I CONFREQ [ACKrcvd] id 1 len 20
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          429: Jul  5 03:23:08.730: As0/463 LCP:    ACCM 0x00000000 (0x020600000000)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          430: Jul  5 03:23:08.730: As0/463 LCP:    MagicNumber 0x020725BB (0x0506020725BB)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          431: Jul  5 03:23:08.730: As0/463 LCP:    PFC (0x0702)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          432: Jul  5 03:23:08.730: As0/463 LCP:    ACFC (0x0802)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          433: Jul  5 03:23:08.730: As0/463 LCP: O CONFACK [ACKrcvd] id 1 len 20
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          434: Jul  5 03:23:08.730: As0/463 LCP:    ACCM 0x00000000 (0x020600000000)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          435: Jul  5 03:23:08.730: As0/463 LCP:    MagicNumber 0x020725BB (0x0506020725BB)
2013-07-05 10:23:08          Local7.Debug          172.30.255.8          436: Jul  5 03:23:08.730: As0/463 LCP:    PFC (0x0702)
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          437: Jul  5 03:23:08.730: As0/463 LCP:    ACFC (0x0802)
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          438: Jul  5 03:23:08.730: As0/463 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          439: Jul  5 03:23:08.738: As0/463 PPP: Phase is AUTHENTICATING, by this end
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          440: Jul  5 03:23:08.738: As0/463 MS-CHAP-V2: O CHALLENGE id 1 len 32 from "novc3925r04"
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          441: Jul  5 03:23:08.738: As0/463 LCP: State is Open
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          442: Jul  5 03:23:08.950: As0/463 PPP: I pkt type 0xC021, datagramsize 20 link[ppp]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          443: Jul  5 03:23:08.950: As0/463 LCP: I IDENTIFY [Open] id 2 len 18 magic 0x020725BBMSRASV5.20
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          444: Jul  5 03:23:08.954: As0/463 PPP: I pkt type 0xC021, datagramsize 28 link[ppp]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          445: Jul  5 03:23:08.954: As0/463 LCP: I IDENTIFY [Open] id 3 len 26 magic 0x020725BBMSRAS-0-NOV001NB29
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          446: Jul  5 03:23:08.958: As0/463 PPP: I pkt type 0xC021, datagramsize 26 link[ppp]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          447: Jul  5 03:23:08.958: As0/463 LCP: I IDENTIFY [Open] id 4 len 24 magic 0x020725BBVBBD0W5G/`}6j]H(
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          448: Jul  5 03:23:08.970: As0/463 PPP: I pkt type 0xC223, datagramsize 63 link[ppp]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          449: Jul  5 03:23:08.970: As0/463 MS-CHAP-V2: I RESPONSE id 1 len 61 from "svodweb"
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          450: Jul  5 03:23:08.970: As0/463 PPP: Phase is FORWARDING, Attempting Forward
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          451: Jul  5 03:23:08.970: As0/463 PPP: Phase is AUTHENTICATING, Unauthenticated User
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          452: Jul  5 03:23:08.974: As0/463 PPP: Sent MSCHAP_V2 LOGIN Request
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          453: Jul  5 03:23:08.974: As0/463 PPP: Received LOGIN Response PASS
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          454: Jul  5 03:23:08.974: As0/463 PPP AUTHOR: Author Data NOT Available
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          455: Jul  5 03:23:08.974: As0/463 PPP: Sent LCP AUTHOR Request
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          456: Jul  5 03:23:08.974: As0/463 PPP: Sent IPCP AUTHOR Request
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          457: Jul  5 03:23:08.974: As0/463 IPCP: Authorizing CP
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          458: Jul  5 03:23:08.974: As0/463 IPCP: CP stalled on event[Authorize CP]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          459: Jul  5 03:23:09.014: As0/463 IPCP: Received AAA AUTHOR Response FAIL
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          460: Jul  5 03:23:09.014: As0/463 IPCP: Event[CLOSE] State[Initial to Initial]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          461: Jul  5 03:23:09.014: As0/463 LCP: Received AAA AUTHOR Response FAIL
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          462: Jul  5 03:23:09.014: As0/463 PPP DISC: LCP authorization failed
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          463: Jul  5 03:23:09.014: As0/463 PPP: Sending Acct Event[Down] id[13D]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          464: Jul  5 03:23:09.014: PPP: NET STOP send to AAA.
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          465: Jul  5 03:23:09.014: As0/463 IPCP: Illegal event DOWN in state Initial
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          466: Jul  5 03:23:09.014: As0/463 IPCP: Event[DOWN] State[Initial to Initial]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          467: Jul  5 03:23:09.014: As0/463 IPCP: Event[CLOSE] State[Initial to Initial]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          468: Jul  5 03:23:09.014: As0/463 CCP: Illegal event DOWN in state Initial
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          469: Jul  5 03:23:09.014: As0/463 CCP: Event[DOWN] State[Initial to Initial]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          470: Jul  5 03:23:09.014: As0/463 CCP: Event[CLOSE] State[Initial to Initial]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          471: Jul  5 03:23:09.014: As0/463 LCP: O TERMREQ [Open] id 2 len 4
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          472: Jul  5 03:23:09.014: As0/463 LCP: Event[CLOSE] State[Open to Closing]
2013-07-05 10:23:09          Local7.Debug          172.30.255.8          473: Jul  5 03:23:09.210: As0/463 PPP: I pkt type 0xC021, datagramsize 8 link[ppp]
2013-07-05 10:23:10          Local7.Debug          172.30.255.8          474: Jul  5 03:23:09.210: As0/463 LCP: I TERMACK [Closing] id 2 len 4
2013-07-05 10:23:10          Local7.Debug          172.30.255.8          475: Jul  5 03:23:09.210: As0/463 LCP: Event[Receive TermAck] State[Closing to Closed]
2013-07-05 10:23:10          Local7.Debug          172.30.255.8          476: Jul  5 03:23:09.210: As0/463 LCP: Event[DOWN] State[Closed to Initial]
2013-07-05 10:23:10          Local7.Debug          172.30.255.8          477: Jul  5 03:23:09.210: As0/463 PPP: Clearing AAA Unique Id = 13D
2013-07-05 10:23:10          Local7.Debug          172.30.255.8          478: Jul  5 03:23:09.210: As0/463 PPP: Phase is DOWN
0 Replies 0
