ACS 1113 hyperterminal problems
mulhollandm
Level 7
Level 7
folks
i have a ACS 1113 appliance which i'm trying to hyperterminal to but with no joy
i'm using
115200
8
N
No flow control
but i can't get anything from the console
i have tried the same on my backup box but still the same
does anyone know the actual settings
thanks to anyone taking the time to reply
smalkeric
Level 11
Level 11
change the console cables. also give the proper console parameter for the console session with the box
i resolved the the problem along the lines of your suggestion
i use both juniper and cisco kit but i had got the db9 plugs mixed up
when i made sure the console cable had a db9 from the acs1113 box it all worked
must have been an issue with pin outs
many thanks for taking the time to reply
