ACS 1113 logon problems
mulhollandm
Level 7
Level 7
folks
i've just got a Cisco 1113 ACS server and have put a minimum config on it (mostly through from lack of knowledge!)
and i'm having some problems
i can logon at the console but i can't logon with the same credentials on the web interface
i had to disable the CSAgent to even get the http session working
is there anything else i need to do
i'm grateful to anyone taking the time to reply
many thanks
iwanc
Got reply from TAC.
The workaround they had was to make sure that the ACS hostname is different from the administator name. So in our case, would you confirm if the ACS hostname and the administrator name given are the same value.
And after I change my administrator name, it works.
changing the name works fine - many thanks
now i just have to find out why it someimtes won't let me logon or why the web page doesn't respond!
