ACS 2.6 problems
williamparis
Community Member
All,
I'm having some problems getting ACS 2.6 NT to work with my 3620. I've got it to where a dialin user will authenticate (or so the ACS auth logs say) but then I get the "cannot log you on -invalid domain/username" error and I get disconnected. This happens for both ms-chap and pap users (NT and Cisco Secure DB). Does anyone have any pointers?
I can provide the relavent bits of the IOS if need be. I really would appreciate some help here as I need to get this done by COB tomorrow! 😮
Details:
Cisco ACS 2.6 on NT.40 SP6
Authentication NT/2000 external db
Radius IOS/PIX
IOS 11.2 on a Cisco 3620
Kind regards,
William Paris
williamparis
Community Member
Problem solved -it turned out to be my Radius Server timeout. I increased it from the default 5 to 30 and all works now.
Thanks for reading.
How/where did you increase the default from 5 to 30??
Thank You
