ACS 5.2 Solution Engine Patches and Installs
Im trying to upload the 5.2 patches to the ACS Solution Engine so i can install the updates.
Does anyone know how to do this or know the links that show how to do this??
The User Guide documentation isnt very helpful.
Marco
Waris Hussain
Hi Marco,
Here is the link for downloading ACS5.2 patches :
http://www.cisco.com/cisco/software/release.html?mdfid=283107438&flowid=18604&softwareid=282766937&release=5.2.0.26&relind=AVAILABLE&rellifecycle=&reltype=latest
Downlaod  any patch  and place in the   FTP/SFTP  server in your enviroment
Login to the ACS CLI :
Create a repository:
acs/admin(config)# repository myrepository
acs/admin(config-Repository)# url sftp://starwars.test.com/repository/system1
acs/admin(config-Repository)# user luke password skywalker
acs/admin(config-Repository)# exit
after that run this command :
acs patch install patch-name.tar.gpg repository repository-name
Installing an ACS patch requires a restart of ACS services.
Would you like to continue? yes/no
once done you can do a sh version and see the acs5.2 with the new patch.
Also when you download the patch there is also read me with similar instructions.
Herre is the link for acs5.2 patch 5 read me link :
http://www.cisco.com/web/software/282766937/37718/Acs-5-2-0-26-5-Readme.txt
Waris Hussain
Waris Hussain
Hi Marco,
Waris Hussain
Hi Waris
Thanks for the reply.
That has worked and now able to update .
Thanks again
Marco
