ACS 5.3 join Two Differents Active Directories without Replicate in the AD's
ivan.martin
Hello my name is Ivan:
I have a question...
Is possible to join the ACS 5.3  to two differents Active Directories that are in two differents networks to use eap peap mschap v 2, with 2 certificates differents, to authenticate users in a wireless network?
I have
AD 1 in the newtork 10.25.1.0/24 with Certification Authority 1
AD 2 in the network 192.168.10.0/24 with Certification Authority 2
Doesn't exist replicate in the  two AD's. The users in the AD 1 are totally diferents of the AD 2.
Both of them AD's I would like to join in my ACS 5.3.
How can I do it?
Thanks for your answers.
Jatin Katyal
Here are few things that we can think of in your scenario.
>            You can't integrate the same ACS server directly to two different AD domains (AD1 and AD2). With ACS 5.3, all you can do, establish 2-way trust between the domains (AD1 and AD2). This way users from trusted domain can authenticate via ACS installed in local domain. You have to add a UPN suffix or NETBIOS prefix ( e.g user@domain-name) to  the username when  authenticating to a domain (Trusted one) that the ACS is not joined  to, including the  child domains.
>           However, with ACS 5.4, you can join the ACS nodes from same deployment to  different AD domains. However, each node can be joined to a single AD  domain.
ACS 5.4 Primary -----  Domain A
ACS 5.4 Secondary---Domain B
Release notes.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.4/release/notes/acs_54_rn.html#wp71092
>            I'm not going to give to an option to integrate ACS with LDAP as an identity database because LDAP doesn't support Peap Mschapv2 so entire purpose of setting up EAP authentication will fail.
Hope it helps.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
7 Replies 7
Jatin Katyal
Release notes.
Hope it helps.
~BR
Jatin Katyal
~Jatin
Did that answer your question? Do let us know if you have any queries.
~Jatin
Hi Jatin,
May I ask you a question please? I have a same issue here.
Our AD is sitting in side firewall, that it has a inside domain internal.domain.com, while we have another outside Internet domain external.domain.com . Our ACS join in internal.domain.com
The outside domain does not have any AD server.
When I was using ACS 5.3, I can add a UPN suffix external.domain.com to combine inside internal.domain.com.
So inside AD can handle both any user wih UPN @external.domain.com and @internal.domain.com
But after we uprade to 5.4, the ACS refuse to send any user with @external.domain.com to inside domain controller. Because acs 5.4 is join in internal.domain.com only.
How can I let the ACS 5.4 still send the external domain name to internal domain control? or setup a default domain?
or do I need to downgrade 5.4 back to 5.3?
Much appreciated for any comments in advance.
Cheers,
Edward
Hi Edward,
If this was working fine with ACS 5.3 then it should work with ACS 5.4 as well.
The reason why I'm saying this because this condition applies to ACS 5.3 as well. "ACS  does not support user authentication in AD when a user name is supplied  with an alternative UPN suffix configured in OU level. The  authentication works fine if the UPN suffix is configured in domain level"  This was documented in all user guides from ACS 5.1 to 5.4.
We've filed a defect as well.
CSCud36340    ACS authentication is not working with alternative UPN from OU level
Now the questions are;
1.] Have you made any changes to AD structure as well. In case, do we have UPN suffix configured in OU level.
2.] Is the 2-way trust between these 2 domains are still there?
3.] Could you please provide nslookup external.domain.com from ACS CLI.
4.] Are you able to fetch external.domain.com groups and user attributes from ACS - Intentity store > AD1 settings > Directory groups
5.] We might need to look at adclient logs and packet capture.
~BR
Jatin Katyal
~Jatin
Hi Jatin,
Many thanks for your information. here are my feedback details:
A: I checked with Microsoft Server team, no changes have been done from their end. The UPN suffice configured in domain level.
     We have two ACS servers, one is in 5.3, the other is in 5.4, the 5.3 one is working fine, but the 5.4 keep rejecting by : 22056 Subject not found in the applicable identity store(s).
A: Since there are no AD controller in external domain, the external domain is just for Internet DNS. All our users are in the internal AD.
A. I put it inot the attachmen file, I mask the realy name and IP, if you need the original name and IP address, may I send it directly to you by email?
A: No, since there are no external domain controller.
     In our ACS 5.3, I aways fetch the internal domain instead. but user will use the @external domain. ACS 5.3 will send both @external.aut.ac.nz to internal AD. but in 5.4 I found that it just rejected to do so.
A: How can I get the ADclient logs
Hi Jatin,
Here is the troubleshoot I did on acs 5.4 server:
acs2/admin# acs troubleshoot adcheck external.domain.com
This command is only for advanced troubleshooting and may incur a lot of network traff
Do you want to continue?  (yes/no) yes
OSCHK    : Verify that this is a supported OS                          : Pass
PATCH    : Linux patch check                                           : Pass
PERL     : Verify perl is present and is a good version                : Pass
SAMBA    : Inspecting Samba installation                               : Pass
SPACECHK : Check if there is enough disk space in /var /usr /tmp       : Pass
HOSTNAME : Verify hostname setting                                     : Pass
NSHOSTS  : Check hosts line in /etc/nsswitch.conf                      : Pass
DNSPROBE : Probe DNS server 156.62.8.1                                 : Pass
DNSPROBE : Probe DNS server 156.62.1.12                                : Pass
DNSCHECK : Analyze basic health of DNS servers                         : Pass
WHATSSH  : Is this an SSH that DirectControl works well with           : Pass
SSH      : SSHD version and configuration                              : Note
         : You are running OpenSSH_5.3p1, CiscoSSL 0.9.8r.1.3.
DOMNAME  : Check that the domain name is reasonable                    : Pass
ADDC     : Find domain controllers in DNS                              : Failed
         : Cannot find information for domain aut.ac.nz in DNS.
         : Most likely causes are:
         :  a) The domain name, aut.ac.nz, that you entered is wrong
         :  b) /etc/resolv.conf does not point to a DNS server that knows
         :     about the domain
         : Configured DNS servers are:
         :  156.62.1.12 (rangitoto.aut.ac.nz): OK
         :  156.62.8.1 (ns-mail.aut.ac.nz): OK
         : If you cannot resolve this issue then get the name of a Domain
         : Controller for aut.ac.nz and rerun adcheck with the
         : -s option.
1 serious issue was encountered during check. This must be fixed before proceeding
Many thanks again,
Cheers,
Edward
Thanks Jatin for your answer
this help me in my scenary.
