Acs 5.3 - wireless conversion from 4.0
steve switzer
Hi All
As previous posters may have noticed i have been given the task of moving the ACS
from 4.0 to 5.3 which turns out to be considerably different.
Sadly i have nothing to test with at the moment so am trying to work it out as best i can
before the abbreviated period of cutover begins.
I have a Service Desk group setting in 4.0
Under groups i have the group settings  and down the bottom i have the following -
(ticked )  Wireless-WCS HTTP
(ticked ) Custom Attributes
Then in the box -
virtual-domain0=CRUK
role0=LobbyAmbassador
task0=Configure Guest Users
task1=Lobby Ambassador User Preferences
Fine but that doesnt translate directly into any 5.3 settings.
I assume that i would do the following
In policy elements create a shell profile (Service Desk) with the following settings -
Privilege level 0
Custom attributes
Manually entered -
attribute              requirement              Value
virtual-domain      mandatory               virtual-domain0=CRUK
role                    mandatory               role0=LobbyAmbassador
task0                 mandatory               task0=Configure Guest Users
task1                 mandatory               task1=Lobby Ambassador User Preferences
submit that and then go to  -
Access Policies/default device admin/Authorisation
Create a new Rule
Add  the correct AD group in compound condition AD-AD1   attribute ExternalGroups  value static
in NDG:Device Type -  reference the WLC (previously created as device type with ip address)
Then in Results reference the above shell profile - Service Desk.
Sorry about the longevity but if this looks ok or rubbish can someone let me know as i wont
have much time to get it working with the real wireless
Thanks in advance
Steve
mansrini
Steve,
The process is correct.. However Iam pointing out the following mistakes
It should not be
rather it should be
virtual-domain0      mandatory               CRUK
In 4.x , virtual-domain0=CRUK means virtual-domain0 is the attribute and CRUK is the value.. Pls follow the same for all the AV pairs listed above..
-Mani
maldehne
Check this post which contains everything you need:
https://supportforums.cisco.com/docs/DOC-17909
Please Make sure to rate correct answers
