ACS 5.4 DACL is not working.
                   We are trying to configure downloadable ACL on ACS 5.4 for wireless users with [WPA2][Auth(802.1X)] authentication. Users are able to authenticate with ACS 5.4 server even in authentication log it is showing configured DACL is getting applied but applied acl is not taking effect on user i.e we have confgured some restrictions in DACL still user is able to access everything.
Attache is the screenshot of passd authentication with DACL.
Need assistance for the same.
Jatin Katyal
The screen shot shows that DACL being pushed from the ACS. I'd like to check if you've "AAA OVERRIDE" option enabled under WLC > WLAN > edit > Advanced > AAA Override.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
Yes AAA Override option is already selected in WLC.
Yusuf,
Please verify if you've configured in the same way.
Policy Elements > Network Access > Authorization Profile, please use the following configuration:
Dictionary Type: Radius-Cisco Airespace
Attribute name: Airespace-ACL-NAme
Attribute Type: String
Value=ACL-WLC ( This would be the name of the ACL that you've created on the WLC)
ACLs on Wireless LAN Controller Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807810d1.shtml#conf
~BR
Jatin Katyal
~Jatin
harvisin
Level 3
Level 3
