ACS 5.4 problems
dchoudhury
Community Member
Am trying to create a access policy in ACS 5.4 through my browsers, but to my surprise am facing a wierd problems trying to access through browsers. Please go through the pics attached below to clearly understand the problem.
6 Replies 6
Jatin Katyal
Chrome is not a supported broswer with ACS 5.4. Have you tried IE or Firefox. Please look below for the supported version of IE and FF.
Supported Web Client and Browsers
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.4/release/notes/acs_54_rn.html#wp222016
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
So you mean to say that only the earlier versions of firefox will work perfectly?? Because as you can see, i have attached the pic taken from firefox too and ours is firefox 24.0 version.
for best results, yes!
The error you are getting with firefox, you need to logout and log back in. I'd suggest you to apply latest patch of ACS 5.4 i.e patch 5. I think this specific issue has been resolve in that.
~BR
Jatin Katyal
~Jatin
Ok thanks Jatin Katyal. I will try to apply the latest patch that you proposed and get back to you if the problem still persists.
Sure. NP.
You can download the patch from here http://tools.cisco.com/squish/2B932
ACS 5.4.0.46.5 Cumulative Patch
5-4-0-46-5.tar.gpg
~BR
Jatin Katyal
~Jatin
Tarik Admani
I have the best luck with IE10 set to compatibility mode. Press F12 when IE is open and select.
Sent from Cisco Technical Support Android App
