ACS 5.5 Primary and Seconday Instance contending issues
   We have two ACS boxes running as a primary/secondary cluster which upon a minor access policy change which brought down a network access group authorization service.
   Since then, we see that the either roles are presented with Primary Instance status wherein the supposedly Secondary node sees itself as Primary.
Any ideas why this could be and how to revert it back to Secondary role?
MSC
Gagandeep Singh
A change made in primary will automatically replicate to secondary. Users authenticating against secondary will also be impacted by the same policy change.
As a case of showing both servers as primary. I would suggest to deregister secondary from deployment. Reload it and make it part of deployment.
Gagan
ps : rate if it helps!!!
Thank you Gagan.
I will try this on Monday and update
Mariano
