ACS for Windows x ACS Solution Engine
lomine
Community Member
Can I replicate user and group databases from ACS for Windows to ACS Solution Engine ? I'm using the same version (3.3) and the same path.
Tks.
umedryk
Level 11
Level 11
As far as I know, you need to enter all the database manually
