ACS NAR Configuration problem
miklos.andrasi
Hi all!
I have a problem with configuration of Network Access Restriction.
I set the feature via Shared Profile Component and Group Level NAR also, but none of them works.
My test AAA client is a VASCO RADIUS Client Simulator. I thought that this software doesn't send the proper RADIUS attributes, but behaviour of ACS is never prohibitive, but sometime it should be.
I tried it with version 3.2 and 4.2 also.
Is there a trick or something I messed up?
Thank you for the answeres!
For wireless user you need to use CLIS/DNIS based access restriction.
If you user Radius IETF for wireless AP, basic authentication should work but issue would be with authorization part.
~JG
Jagdeep Gambhir
Level 11
Level 11
NAR works on the basis of attributes sent by aaa client.
IP-based NAR filters work only if ACS receives the Radius Calling-Station-Id (31) attribute. The Calling-Station-Id (31) must contain a valid IP address. If it does not, it will fall over to DNIS rules.
See this link
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.1/user/SPC.html#wpxref8530
~JG
Do rate helpful posts
Would it be problem, if I use RADIUS (IETF) "Authentication using" in the Network Configuration in ACS for Wireless AP? The productive envirement contains this configuration, and another device with TACACS+ configuration.
~JG
Thank you for your answers. If I use CLIS/DNIS based access restriction, it works but in case of router works only with CLIS/DNIS based access restriction also. It's interest for me.
Miki
