ACS Problem
ismail884
I have 2 ACS SE 4.1 servers implemented to perform redundancy to client's authentication.
The problem that I have is:
I configured the 2 engines with IP addresses and also internal DB replication so the Primary ACS send replication data to the Secondary ACS as follow.
ACS_PRI: (Self):10.10.1.10 and I added the Secondary ACS as an AAA server to the ACS PRI AAA table with the Address 10.10.1.11.
ACS_SEC: (Self):10.10.1.11 and I added the Primary ACS as an AAA server to the ACS SEC AAA table with the Address 10.10.1.10.
For the first time all operations seem operational but when I shutdown the ACS servers for a while, I note that the AAA servers table is changed and clients cannot authenticate.
After booting the ACS servers the AAA servers Tables are as follow:
In the Primary ACS: (self):127.0.0.1
DELIVRANCE1:10.10.1.10
ACS_SEC :10.10.1.11
In the Secondary ACS: ACS_SEC:10.10.1.11
Before shutting down ACS servers AAA servers' tables were:
In the Primary ACS: (self): 10.10.1.10
ACS_SEC:10.10.1.11
In the Secondary ACS: (self):10.10.1.11
ACS_PRI:10.10.1.10
Thanks for your assistance
Ismail
Jagdeep Gambhir
Level 11
Level 11
Ismail,
Pri acs
Go to acs---> Network configuration---->Proxy dis table--->default---->Make sure DELIVRANCE1 is in forward to box
~JG
