ACS solution engine boot problem
davidcruise
Level 2
Level 2
i have cisco ACS solution engine 1113 , when i power up the appliance , it gives me the following output:
ThinkVantage Secure Data Disposal Utility 3.
Date and time of execution ... 03/21/08 07:21:48
Command executed ............. A:\SCRUB\SCRUB3.EXE /d=ALL /l=1
Return code .................. 0
is this hardware failure or it needs reimaging
Jagdeep Gambhir
Level 11
Level 11
Yes, this is a hardware failure. Please get it replaced.
~JG
Do rate helpful posts
