ACS testing problem
c_kumar001
Community Member
I have acs server installed on windows 2003 server. I am using 2 nic , sometimes it pings to the server address but testing is fail.
It shows no authoritive response from server. When I restart my pc it starts testing again.I think its two nic problem.
Can anyone suggest me another way of doing  the successfull test without restarting my pc.
Plz Help me.
Tarik Admani
Chandan,
The guide explains how this was tested using one nic, are both nics plugged in when you perform your test?
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2.1/Installation_Guide/windows/install.html#wp1041506
If so, please unplug one of the nic cards, reboot and see if this fixes your issue.
Tarik Admani
Yes, both nics are plugged in at the time of testing.Conectivity test is successful but protocol testing donot work
Single nic works well ...but problem is that i cannot unplug another nic and reboot . Isnt there any other way ..I tried to restart from ACS>system configuration>service control. but still it didnt work
This isnt supported -
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsr76897
There is a feature enhancment that hasnt been addressed, you will have to reach out to your account team for them to provide a roadmap with regards to this feature request.
Tarik Admani
