Another problem with auth-proxy/ACS/Tacacs+
e-alvarez
Level 2
Level 2
I´m trying to use auth-proxy to authenticate user to access the internet. I´m using a C877/Adsl (C870-ADVSECURITYK9-M), Version 12.3(8)YI2 and ACS (CiscoSecure ACS Trial,Release 4.0(1) Build 27).
The problem I´m having is that apparently the ACS is authenticating and authorising user 'tacacs', but the authorisation pop-up windows says Authorisation Failed and the user cannot get past that point.
This is the first time I use ACS, so I´m sure the problem is on the server side since auth-proxy works ok locally on the router. In the attachement you will find the router config,as well as some debugs.
Any help will be much appreciated.
Eduardo
liamkennedy
try upgrading to 12.4 - i've found several different versions of 12.3 which have had tacacs related bugs in them (admittedly this was for VPN authentication)
Thanks, Liam.
Actually, my problem was that I had not configured the necessary attributes under the New Services->autht-proxy. Didn`t have priv-lvl=15 🙂
Thank again for your help.
