ASA in multi context mode and AAA based on context
endpoint
Hello, running ASA5520 in multicontext mode, and would like to apply AAA in separate contexts; eg. context A and B should have AAA authentication and context C not.
I am familliar how to setup AAA in single firewall mode but not sure about correct procedure when setting up AAA in multicontext mode.
Is it possibe to configure individual contexts for AAA?
amitaaga
Yes, it is possible to setup AAA in individual contexts. The procedure is going to be exaclty the same as when the firewall is in single context mode.
Just be careful while configuring command authorization on a firewall in multiple context.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mgaccess.html#wp1060011
Hope it helps.
Amitashwa
