ASDM/HTTP Authentication issue with 8.2 using SDI
amardram123
Level 3
Level 3
ASDM/http authentication for ASA 5550 using SDI
I want to setup http authentication for ASA 5550 using SDI, Ciurrently i am running 8.05 and this feature is not supported
I have gone through couple of cisco docs and find conflict, One doc says 8.2 supports ASDM authentication using SDI protocol and other mentioned it doesn't support.
This Cisco doc says it doesn't support:
HTTPS management authentication does not support the SDI protocol for a AAA server group.
This Cisco doc says it supports:
Cisco ASDM OTP authentication, authorization, and accounting (AAA) support: This support allows administrative users to authenticate Cisco ASA appliances and ASDM through OTPs supported by RSA SecureID. This feature addresses security concerns associated with administrators using static passwords for authentication.
need help...
Regrads
Amar
madhusudhan s
Level 3
Level 3
Opened a TAC and he confirmed that 8.2.1 supports the SDI for http/asdm authentication.
http://www.cisco.com/en/US/docs/security/asa/asa82/release/notes/asarn82.html#wp340497
Amar
