Authentication problem with Cisco 3005 and MS RADIUS
ethanhays
I am trying to set up authentication for VPN clients (software) to a Cisco 3005 concentrator through MS RADIUS
on win2k server. I have gone through the Cisco example configurations, which worked
great for setting up hardware clients, but is not working for my software clients.
When trying to authenticate win2k server, test authentication from the concentrator works fine. The client
does not see any error message, it just goes through the process and disconnects.
The client log is showing (sorry if this is a little long):
40 08:15:55.296 11/11/05 Sev=Info/5 IKE/0x6300003C
Received a DELETE payload for IKE SA with Cookies:
I_Cookie=508F2B7F7B7C8497 R_Cookie=35DCC0259EE6FD37
41 08:15:55.296 11/11/05 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to 172.30.128.3
42 08:15:55.296 11/11/05 Sev=Info/4 IKE/0x63000048
Discarding IPsec SA negotiation, MsgID=075ECA6A
43 08:15:55.296 11/11/05 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=508F2B7F7B7C8497
R_Cookie=35DCC0259EE6FD37) reason =
PEER_DELETE-IKE_DELETE_UNSPECIFIED
44 08:15:55.718 11/11/05 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
45 08:15:56.218 11/11/05 Sev=Info/4 IKE/0x6300004A
Discarding IKE SA negotiation (I_Cookie=508F2B7F7B7C8497
46 08:15:56.218 11/11/05 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
47 08:15:56.218 11/11/05 Sev=Info/4 IKE/0x63000085
Microsoft IPSec Policy Agent service started successfully
48 08:15:56.718 11/11/05 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
49 08:15:56.718 11/11/05 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
50 08:15:56.718 11/11/05 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
51 08:15:56.718 11/11/05 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
The concentrator log shows the following:
10849 11/11/2005 08:26:48.630 SEV=4 IKE/52 RPT=115 172.30.144.96
Group [IndividualNT] User [<username>]
User (<username>) authenticated.
10850 11/11/2005 08:26:48.640 SEV=5 IKE/184 RPT=106 172.30.144.96
Client OS: WinNT
Client Application Version: 4.0.1 (Rel)
10852 11/11/2005 08:26:49.480 SEV=4 IKE/119 RPT=145 172.30.144.96
PHASE 1 COMPLETED
10853 11/11/2005 08:26:49.490 SEV=5 IKE/25 RPT=3768 172.30.144.96
Received remote Proxy Host data in ID Payload:
Address 172.30.128.100, Protocol 0, Port 0
10856 11/11/2005 08:26:49.490 SEV=5 IKE/34 RPT=3906 172.30.144.96
Received local IP Proxy Subnet data in ID Payload:
Address 0.0.0.0, Mask 0.0.0.0, Protocol 0, Port 0
10859 11/11/2005 08:26:49.490 SEV=4 IKE/1 RPT=480 172.30.144.96
Received invalid phase 2 L2TP/IPSec Responder ID payload
Expected ID: Type 1, Proto 17, Port 1701, Addr 172.30.128.3
Received ID: Type 4, Proto 0, Port 0, Addr 0.0.0.0
10863 11/11/2005 08:26:49.490 SEV=4 IKEDBG/0 RPT=517
QM FSM error (P2 struct &0x1d284fc, mess id 0x2b2a1a0a)!
10864 11/11/2005 08:26:49.490 SEV=4 IKEDBG/65 RPT=1036 172.30.144.96
IKE QM Responder FSM error history (struct &0x1d284fc)
<state>, <event>:
QM_DONE, EV_ERROR
QM_BLD_MSG2, EV_NEGO_SA
QM_BLD_MSG2, EV_IS_REKEY
QM_BLD_MSG2, EV_CONFIRM_SA
I've been working on this for 2 days, and can't figure out why clients can't connect. Any help would be greatly appreciated.
mchin345
Level 6
Level 6
Some RADIUS servers do not support MSCHAPv1 or MSCHAPv2 user authentication. If you are using a RADIUS server that does not support MSCHAP (v1 or v2), you must configure the Base Group's PPTP authentication protocol to use PAP and/or CHAP and also disable the MSCHAP options. Examples of RADIUS servers that do not support MSCHAP are the Livingston v1.61 RADIUS server or any RADIUS server based on Livingston code.For more information refer to the following url:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00800949da.shtml
Thanks for the respone. I see that I should have been more specific in my post; I am using microsoft IAS as a radius server, in addition to which, I have tried changing authentication protocols to no avail. The current configuration comes closest to working, and prduces the output seen above. Other configurations either disconnect befor easking for a password, or do not accept the password. The current behavior is that the client software (cisco vpn client) asks for the password, appears to accept it, then disconnects without any error message on the client side at all.
Ethanhays,
Were you able to solve this issue? I am having exact same problem. VPN with ISA as RADIUS auth was woking fine up until last week. All of the sudden VPN with ISA auth stop working with exact same error as above. I suspect Microsoft hotfix but do not know which one as there are millions of them every week. Any information would be greatly appriciated.
