Authorization Policy for a device that goes Wired and Wireless
Bobby M
Frequent Visitor
Frequent Visitor
I'm in an environment with many devices that go between wired and wireless both requiring an ACL on the WLC and a dACL.
Is it possible for me to utilize a single Authorization profile that can be used for both a wired and wireless connection? So it would appear to have 4 attributes (dACL+ Vlan ) and an (Airespace-ACL-Name + Airespace:Airespace-Interface-Name) instead of two separate options.
Sure, if you have a 9800 running 17.10 or later you can use the same dACL for both.  Otherwise, no you cannot combine attributes like that.  The switch will not understand what to do with an Airespace ACL and the authz would likely fail on the switch.
