Automatic Admin Node Failover for more small deployments
rmueller@cisco.com
Hi folks,
my customer is planning to deploy ISE in a small deployment: One node as PAN/MnT/PSN and a second node also with Admin(secondary)/MnT/PSN.
Now he would like to deploy a 3rd node to act as a health-check node to support automatic failover for Admin node.
According to the scaling guidelines, it is not supported to register a 3rd node to a 2-node deployment where the two nodes have all three  personas. Is there an exeption for the case of the health check node? So would the following deployment be allowed/supported:
ISE -instance 1: PAN/MnT/PSN
ISE-instance 2: (s)AN/MnT/PSN
ISE-instance 3: PSN, health-check (PSN will not be used as such, no RADIUS-requests will be sent to that node)
Thanks in advance.
Roland
howon
No this design hasn't been tested, and thus not supported.
howon
Craig Hyps
Level 11
Level 11
Hosuk is correct.  The basic requirement that you have an "objective observer" to make the failover decision.  The Primary PAN cannot monitor itself and concern over Secondary making that decision is that if break link between Primary and Secondary, then increase potential for a split brain (Active/Active) deployment where connectivity between NADs is still possible to individual nodes.  Architecture currently does not support an "auto-reconciliation" of config changes or data that may have been learned during Active/Active, so decision made to make sure health check node is separate.
Craig
Hi Craig,
thanks for the explanation.
I am fine to have a seperate node as health-check node, but if I follow strictly the deployment guide I have to move from a "small" deployment (with only two "productive" nodes) to a medium deployment, otherwise I am not allowed to register a seperate health-check node. This means, although two nodes would be fine scalability wise, the customer would have to deploy 4 ise instances + health node just to get automatic PAN failover.
Or do I miss something?
Roland
Correct.  Unfortunately we do not QA test a scenario where we have a separate check node with no other function.  Although no testing to support, I would expect minimal impact if no User Services (RADIUS / Profiling) or optionally pxGrid services, however, there is still an impact on the PPAN node to maintain health and replication of this additional node. It may still be minimal, especially if node has reasonable connectivity (minimal WAN latency/bw for replication), the actual impact is not measured.  Consequently, you could configure it and it may present minimal risk, but any issues related to deployment stability or scaling will likely bring this configuration into question and could require de-registration for continued TAC support.
Hope that clarifies.
Craig
