BYOD Single versus Dual SSID Flow
GQ
just quick anectodal fact finding, do you advocate (or which do you mostly see) with BYOD: single or dual SSID registration flows?
assuming modern advances in iOS, Android, Windows, and WLC/ISE code?
Is it a simple question of 'if mobile OSs only, single SSID makes more sense' or 'if organization already has an open Guest SSID, use Dual'?
hariholla
We do not have latest CVD on BYOD, but here's what we have from the last written document in this aspect:
Some considerations when selecting a single versus dual SSID configuration:
  • Some organizations prefer having a dedicated SSID for on-boarding devices.
  • Others see dual SSID as an extra management burden.
  • A second SSID adds channel overhead.
  • Enabling too many SSIDs may degrade wireless performance.
The organization’s unique requirements and preferences will dictate which model to deploy. The configurations of both the ISE and WLC may be easily modified to support either single or dual SSID deployments.
Cisco Unified Access (UA) and Bring Your Own Device (BYOD) CVD - BYOD Wireless Infrastructure Design [Design Zone for En…
5 Replies 5
gbekmezi-DD
Level 5
Level 5
Since you are asking for anecdotal feedback, I prefer single SSID whenever possible.
hariholla
Adding to Hari's list:
Pros of Single-SSID:
  • User experience is better for iDevice users as SSID switching from OPEN to SECURED does not require user intervention
  • This is a unique capability of ISE where competitor solution forces user to login twice while ISE can take user information from 802.1X session without asking for the user to login again to the web portal
  • Fast-SSID change does not need to be enabled on the WLC
Pros of Dual-SSID:
  • Can provide visible guidance to the user on the BYOD process before logging in
Other cases where dual-SSID may be favored include:
* ID Store is LDAP and cannot start with PEAP with MSCHAPv2 currently to LDAP store
* Wired deployment where cannot assume client already has 802.1X enabled on wired interface.
howon
FYI, I've consolidated the answers here:
ISE BYOD: Dual vs. Single SSID Onboarding
