Cisco ACS 5.X and Radius using AD
Bobby Roberts
Hello All - I am currently useing ACS 5.2 and have no problem using Tacacs+ with AD access.
But with Radius it seems I can only get the Local identity store to work, does anyone know if you need to do something special to get Radius to work with active directory with Cisco ACS?
Hello Bobby,
would you please include screen shot for:
1) access policies ->> default device admin ->> group mapping
2) access policies ->> default network adming->> group mapping
Kind regards
Talal
10 Replies 10
Bobby Roberts
Just to note,  I keep getting
Failure Reason :
22056 Subject  not found in the applicable identity store(s).
Any help here?
Hello Bobby,
can you please attach screen shots of following configuration:
users and identity stores ->> active directory.
both TABs , genearal and direcotry groups.
Kind regards
Talal
It is working for Tacacs+  but not Radius
the Directory Groups has two groups,  one for R/W and one for R/O.
Hello Bobby,
Kind regards
Talal
Ah, i looked there and noticed that the Default Network Admin was setup for Internal only, i moved it over to use the active directory,   but now i'm getting
15015 Could not find ID Store
perfect ;o)
Bobby, I ran into the same issue with the "15015 Could not find ID Store" issue.  It turned out to be an issue with communication between the ACS and AD.  It looked like AD was connected successfully, but until I rebooted ACS, I kept getting the same error.  It was like it couldn't see the AD security groups even though it could scan the AD tree successfully.
So, try rebooting ACS if you haven't already and see if that resolves the error.
Tim - I was able to get it to work after I setup the correct authentication in the ACS and tell it what shell to run.
