Cisco AnyConnect triggering Problem!!!
s.maxina1
Level 4
Level 4
Hi All.
I Have configured Cisco ISE v2.4 Posture to check that is Client Windows up to date or not with Cisco AnyConnect module.In my case, Any connect can only check that the windows is up to date or not, but does not automatically triggers the Microsoft Windows Update Agent to connect to the WSUS. Only a window get opened and show remediation timer. when I manually update the windows by myself, this condition is passed and my pc will be compliant. Also, it is noticeable that I have this problem about antivirus remediation and I have to manually update antivirus(Cisco AnyConnect does not automatically triggers the antivirus again).
I will appreciate if someone help me to resolved this problem.
best regards,
Sina HR.
0 Replies 0
