Cisco ISE Authorization Problem
tarek issa
Hi ,
Problem with authorization policy on cisco ISE .
Only one endpoint is not going through authorization policy . although authentication is okay and  posture is okay .
but after that the endpoint doesnt take any authorization profile. even though I created a rule to allow any endpoint to take allow any profile.
Logs showing endpoint stuck in posturing but after successful posture check the endpoint doesnt take any profile .
problem is with only one Endpoint .
Francesco Molino
Can you tell us more info please?
Share also please your log detail from ise and your policies configuration.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
hslai
Please ensure authenticate, authorization, and posture are all done against the same ISE node.
