ā08-09-2016 11:56 PM - edited ā03-10-2019 11:59 PM
Hi, Experts i synched ISE with NTP Server using UTC timezone. ISE was synched working fine joined AC and LDAP. but when i am restarting ISE (Poweroff/on) i am facing weired issue. demanding for root linux password which did't asked during ISE installation. i am adding error image and putting in text.
***An error occured during the file system check.
***Dropping you to a shell:; the system will reboot
give root password for maintenance
(or type Control-D to continue):
help would be appreciated
ā08-10-2016 08:38 AM
Your image or VM is corrupted.
You will need to either re-image and restore from backup (if you have one) or else open a TAC case to recover.
ā01-28-2017 01:45 AM
Hi Marvin
Image was built in server, When i started server Image directly bootup to the setup so installed and run. rather the case is above.
ā01-28-2017 07:37 PM
If it is a hardware appliance then you should use the procedure to recover using the iso image.
ā01-30-2017 02:13 AM
There was't any backup file or disk/USB. I download ISE 1.4, 1.5 and 2.0 but they thos IOSs were not compatible with that hardware "SNS-3415".
i was able to do on ESXi but i dont want this.
ā01-30-2017 05:44 AM
ISE 1.4 and higher is compatible with the SNS-3415 appliance.
Reference: http://www.cisco.com/c/en/us/td/docs/security/ise/1-4/installation_guide/b_ise_InstallationGuide14/b_ise_InstallationGuide14_chapter_010.html
For instance, the file "ise-1.4.0.253.x86_64.iso" is titled ""Cisco ISE Software Version 1.4.0 full installation(no IPN functionality).This ISO file can be used for installing ISE on ISE-33x5, NAC-33x5 Appliances, and SNS-34x5 Servers as well as a VM installation on VMWare ESX/ESXi 5.x ".
The SNS-3415 can be recovered via mounting the IOS when using the CIMC port:
http://www.cisco.com/c/en/us/td/docs/security/ise/1-4/installation_guide/b_ise_InstallationGuide14/b_ise_InstallationGuide14_chapter_011.html#ID-1415-00000153
ā01-30-2017 08:09 PM
Thank You Marvin . i tried it 5 month ago but now i will this try this speific file.
yes the links you mentioned above there is Caution
"Changing the time zone on a Cisco ISE appliance after installation causes the Cisco ISE application on that node to be unusable. " that i did š
One more thing which i may to know 1.4 is also compatible with SNS3515? if i am forgetting the model because its on client side.
Will update you shortly about the activity.
ā01-31-2017 04:33 AM
The 3500 series appliances (3515 and 3595) require ISE 2.0.1 or later. That release introduced support for the secure boot (UEFI) that these appliances require.
Reference: http://www.cisco.com/c/en/us/td/docs/security/ise/2-0-1/install_guide/b_ise_InstallationGuide201/b_ise_InstallationGuide201_chapter_01.html#id_11131
