Cisco ISE NTP problem
ciscodevi
Visitor
Hi, Experts i synched ISE with NTP Server using UTC timezone. ISE was synched working fine joined AC and LDAP. but when i am restarting ISE (Poweroff/on) i am facing weired issue. demanding for root linux password which did't asked during ISE installation. i am adding error image and putting in text.
***An error occured during the file system check.
***Dropping you to a shell:; the system will reboot
give root password for maintenance
(or type Control-D to continue):
help would be appreciated
7 Replies 7
Marvin Rhoads
Your image or VM is corrupted.
You will need to either re-image and restore from backup (if you have one) or else open a TAC case to recover.
Hi Marvin
Image was built in server, When i started server Image directly bootup to the setup so installed and run. rather the case is above.
If it is a hardware appliance then you should use the procedure to recover using the iso image.
There was't any backup file or disk/USB. I download ISE 1.4, 1.5 and 2.0 but they thos IOSs were not compatible with that hardware "SNS-3415".
i was able to do on ESXi but i dont want this.
ISE 1.4 and higher is compatible with the SNS-3415 appliance.
Reference: http://www.cisco.com/c/en/us/td/docs/security/ise/1-4/installation_guide/b_ise_InstallationGuide14/b_ise_InstallationGuide14_chapter_010.html
For instance, the file "ise-1.4.0.253.x86_64.iso" is titled ""Cisco ISE Software Version 1.4.0 full installation(no IPN functionality).This ISO file can be used for installing ISE on ISE-33x5, NAC-33x5 Appliances, and SNS-34x5 Servers as well as a VM installation on VMWare ESX/ESXi 5.x ".
The SNS-3415 can be recovered via mounting the IOS when using the CIMC port:
http://www.cisco.com/c/en/us/td/docs/security/ise/1-4/installation_guide/b_ise_InstallationGuide14/b_ise_InstallationGuide14_chapter_011.html#ID-1415-00000153
Thank You Marvin . i tried it 5 month ago but now i will this try this  speific file.
yes the links you mentioned above there is Caution
"Changing the time zone on a Cisco ISE appliance after installation causes the Cisco ISE application on that node to be unusable. " that i did 😞
One more thing which i may to know 1.4 is also compatible with SNS3515? if i am forgetting the model because its on client side.
Will update you shortly about the activity.
The 3500 series appliances (3515 and 3595) require ISE 2.0.1 or later. That release introduced support for the secure boot (UEFI) that these appliances require.
Reference: http://www.cisco.com/c/en/us/td/docs/security/ise/2-0-1/install_guide/b_ise_InstallationGuide201/b_ise_InstallationGuide201_chapter_01.html#id_11131
