Cisco ISE Two-factor authentication Need Help
uzair.infotech
Level 2
Level 2
Our customer is operating Cisco ISE Version: 2.3.0.298 with Base license. Client want to implement Two-factor authentication with RSA Secure ID.
Please help whether client is required to upgrade the license or Cisco ISE Base license will support the Two-factor authentication.
Mike.Cifelli
So base licenses will cover the following:
Network access: AAA, 8021x, etc.
Guest Management
MACsec
Trustsec
ISE APIs
I assume your client wants to implement 2-factor for device administration. If that is the case you will need Device Administration licenses which support the use of TACACS+ for 2FA. If your use case is something different this may better assist you:
https://community.rsa.com/docs/DOC-66799
HTH!
Mike.Cifelli
Guest Management
MACsec
Trustsec
ISE APIs
HTH!
Thank you Mike.
My client want to use 2-factor authentication for LAN users not for device administration.
No problem. For your case you may want to consider looking into using Anyconnect NAM with EAP-GTC.
