Cisco Secure ACS 4.0 Solution engine problem
Goblet101
Community Member
I have a probleme with a Cisco Secure ACS 4.0 Solution Engine (CSACSE-1113-K9).
I try to power up the engine, but the light in the power button stay blinking all the time. Anyone have a idea why ?
Last week, I boot it for the first time (It's brand new), every things goes fine.
I made " shutdown " then wait the message to press 4 seconds power button to turn it off. This morning, nothing come up.
I see one thing in the console "Press <SpaceBar> to update BIOS." after that, blank. No bios detection, no harddrive dectection, no windows boot.
Any idea ?
Thank you
jreekers
Level 8
Level 8
Hi.
Are you sure you're not talking about #8 as shown in this diagram:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/csapp32/install/ovrvuap.htm#wp1026107
Which just is used for unit identification??
No, I'm sur.
Then we have version 1113 of ACS.
See: http://www.cisco.com/application/pdf/en/us/guest/products/ps6731/c2001/ccmigration_09186a008068f7bd.pdf
Page 32(1-8) #2.
I let the engine off about 6hours after my first post, then I try back. The engine start.
What can cause this problem ?
