Cisco Secure ACS solution Engine Server Specifications
wmmak
Level 4
Level 4
Dear All,
May I know if the latest ACS enginer server contains any DVD-ROM drive?
It only mentions floppy disk in data sheet.
mak
pcomeaux
Hey mak -
Looks like the 3.2 and 3.3 versions of the ACS appliance has a CD-ROM - 24x Slim CD-ROM.
I haven't seen one in person, but found this data in the Technical Specifications in the Documentation Guides.
Here's the links:
3.2 - http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/csapp32/install/spcsap.htm
3.3 - http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/csapp33/install/spcsap.htm
The ACS image is usually about 100 megs for a full install for the windows only version. Do you need the disk density of a DVD drive?
thanks!
peter
Hey Peter,
Could you please help me with a query as I have limited experience with CiscoWorks LAN Management.
Can you run Cisco Secure ACS and CiscoWorks LAN Management on the same server ? I have read the minimum requirements and according to the minimum requirements it is possible but i dont know if limitations make it impossible.
Your help would be greatly appreciated
Chris
