Cisco SNS 3415 System Status LED is Amber and blinking
Hi All,
one of the ISE Node System Status LED is Amber and blinking (Warning Symbol LED)  Any troubleshooting procedure for the same to isolate.
Note: server is reachable and application is accessible.
Any help could be appreciated.
Regards ...Laxmi
Based on the documentation it's a critical state:
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/installation_guide/ise_ig/ise_app_a-prep_ins.html?bookSearch=true#pgfId-1113350
I would open a TAC-case for that.
we would be open the tac case. but want to understand if can we identify if any logs can be viewed, to isolate the issue.
Regards Laxmi
As Karsten noted, a TAC case is your best option.
Those servers are based on the Cisco UCS C200 series so, as far as local logs, you should be able to see the cause of the blinking light via the Cisco Integrated Management Controller (CIMC) GUI.
Here's a link to the instruction for doing so:
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/sw/gui/config/guide/2-0/b_Cisco_UCS_C-series_GUI_Configuration_Guide_201/b_Cisco_UCS_C-series_GUI_Configuration_Guide_201_chapter_01110.html
